robertson.michael Fri, 09/12/2008 - 06:07
  • Silver, 250 points or more
Hi Julie,
To add a user and give htem read-only access to ASDM, you simply need to create a new user with a privilege level of 5. On the CLI, it will look something like this:
username cisco password cisco123 privilege 5
Here is the config guide for doing this through ASDM as well:
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/aaasetup.html#wp1284477
Also, if the command has already not been enabled, you will need to tell ASDM to authenticate users against the local user database:
aaa authentication http console LOCAL
Hope that helps.
-Mike
julxu Sun, 10/12/2008 - 18:53
still have problem.
I have multi-contents, and the read only user can only see on context, not others? how can I make the readonly user to see all the contexts but no configure them?
suschoud Fri, 09/12/2008 - 06:28
  • Gold, 750 points or more
Just make sure you also have :
privilege level 5 mode configure command asdm
command in the config.
Please rate if helps.
Sushil
julxu Thu, 09/18/2008 - 22:56
Thanks for both replys.
regards "privilege level 5 mode configure command asdm", please advice:
if user0 have privilege 2 (default), and user1 has privilege 5, so user1 should be readonly user, what about user0? does user0 still can use asdm to change configuration on ASA5520?
Please advice
julxu Sun, 10/12/2008 - 20:03
still have problem.
