SNMP configuration
Sep 11th, 2008
Hi, I am troubleshooting with SNMP trap, I am receiving trap from one router but not from another, both router has been configured in mpls. Can you give me the basic SNMP configuration for MPLS.
guruprasadr Fri, 09/12/2008 - 01:37
  • Gold, 750 points or more
HI Goutam, [Pls RATE if HELPS]
Please find the SNMP Configuration template:
snmp-server community xxxxxxxxxxx RO 98
snmp-server community yyyyyyyyy RW 36
snmp-server trap-source Loopback0
snmp-server enable traps snmp linkdown linkup
no snmp-server enable traps tty
snmp-server enable traps mpls ldp session-up session-down
snmp-server host aaa.bbb.ccc.ddd xxxxxxxxxxx
The Command below will enable the monitoring the MPLS LDP Neighbor Sessions:
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
goutam_04 Fri, 09/12/2008 - 01:51
I will check it later. but can you tell me why "no snmp-server enable traps tty " given this and I want to tell you another things that is... for SNMP Trap vrf is configured in the router and the same vrf is allowed in loopback interface.
I am giving you the total configuration related to SNMP. please can you tell me which command is wrong and any extra commands is need to configuration or not to received the trap, I m not getting trap. Its very urgent.
gagarwal4 Wed, 09/17/2008 - 03:55
Please try following commands and check
snmp-server trap-source Loopback77
gagarwal4 Fri, 09/19/2008 - 02:04
I see following commands missing in router :-
snmp mib community-map globeR engineid 8000000903000018742FDE80
snmp mib community-map [email protected] engineid 8000000903000018742FDE80
snmp mib community-map [email protected]-0 engineid 8000000903000018742FDE80
snmp mib community-map [email protected]-1 engineid 8000000903000018742FDE80
snmp mib community-map globeRW engineid 8000000903000018742FDE80
goutam_04 Thu, 09/25/2008 - 18:22
Hi can you confirm me that the MIB configuration should be same in both routers or not.
