Tomcat Directory
Answered Question
Sep 11th, 2008
  • Silver, 250 points or more
Some time ago I had a weird problem. An application I wrote used XML to get some data. Normally you put this XML file in the C:\Program Files\wfavvid\tomcat\webapps\ROOT directory. But it didn't work.
After a long search and trying I found the directory: C:\Program Files\wfavvid\Documents\user\default\webapps\ROOT.
When I put my XML file here all worked fine.
I had to reinstall this IPCC server and after the reinstall (version 4.0.4) the normal directory worked. The original version was 4.0.1.
Now I have another case using version 4.5 and I have the same issue again. The normal directory doesn't work and I have to use the other directory.
When I do: http://<ip-address>:8080 on a good machine I see:
Cisco Customer Response Solution Engine 4.0
Copyright © 2004 by Cisco Systems, Inc.
On the wrong machine I get something like TOMCAT directory listing.
Any idea? And is this alternative directory stable? And why???
JH
Correct Answer by Jonathan Schulenberg about 8 years 10 months ago
You should be using the document repository for this.
You will be loosing access to the local file system in UCCX 8 when it transitions to a Linux appliance anyways...
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Fri, 09/12/2008 - 02:40
  • Cisco Designated VIP,
    2017 IP Telephony
j.huizinga Fri, 09/12/2008 - 02:58
Thank you!
I never new this!
JH
