Adding VPN users to 1801 router
Answered Question
Sep 12th, 2008
Can anyone tell me how to add additional users to a VPN on an 1801 router. Currently there are 2 usernames we can use to get access via VPN but I'd rather have more as both these accounts mirror admin accounts on our network. We are using Easy VPN Server (I think!) and I have next to no experience on Cisco kit. Many thanks in advance!
Correct Answer by singhsaju about 8 years 7 months ago
Can you post your config ? Maybe your vpn user database is on AAA server .
But if the vpn user database is local on the router, just add a new username/password .
For example:
username cisco password 0 cisco
Saju
Overall Rating: 3 (5 ratings)
Correct Answer
singhsaju Fri, 09/12/2008 - 05:54
  • Silver, 250 points or more
For example:
Saju
richardbruce Fri, 09/12/2008 - 06:13
Thanks for this, I had been using the SDM software and had added a new user but the VPN connection wouldn't recognise it. From what I can tell, all the Authorization is local so I'm not sure why this new user cannot get access.
richardbruce Fri, 09/12/2008 - 06:37
Thanks Saju, I had added a new user via SDM and it wouldn't let them on via VPN, I deletedthem and added them via the command line and now it will let them on via VPN. I guess there must be some difference in how they get added but since it is working now I don't care.
Many many thanks for your help
singhsaju Fri, 09/12/2008 - 06:39
You are welcome .I am glad its working now.
