BARS doesn't delete backups
Answered Question
Hi Huys,
I'm running UCCX/IPCC 5.0(2) Build064. BARS is configured to hold only 4 backups, but it just keeps on collecting backups. And doesn't throw the older ones away.
The Backup is made localy on the C drive, and the pulled by an external backup server.
Can someone help me with this issue?
Best regards,
Paul van den IJssel
Digacom
Correct Answer by Michael Owuor about 8 years 7 months ago
Hi Paul,
You are likely running into a known issue which is documented in CSCsl07961.
To apply the fix to a 5.0(2) UCCX server, apply the SR1 patch
Hope this helps.
Michael.
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Owuor Fri, 09/12/2008 - 21:04
  • Cisco Employee,
Hi Paul,
Hope this helps.
Michael.
