1811 want and switch port connection
Answered Question
Sep 12th, 2008
can i put all 8 switch ports in one vlan. after assigning IP, on interface vlan 10 i'll give ip 10.1.1.1 . can i use "ip nat inside" on interface vlan 1 ??
Correct Answer by Edison Ortiz about 8 years 4 months ago
Usman,
Your original post made me believe you understood the configuration.
Say, you want ports 1-4 to be in Vlan 20(inside Vlan) and ports 5-8 in Vlan 10 (outside Vlan)
1) Create the Vlans in the switch database
Rack1SW1#vlan database
Rack1SW1(vlan)#vlan 10 name outside
VLAN 10 added:
Rack1SW1(vlan)#vlan 20 name inside
VLAN 20 added:
2) Assign the ports to their respective Vlans:
Rack1SW1(config)#int ran f1/1 - 4
Rack1SW1(config-if-range)#switchport access vlan 20
Rack1SW1(config)#int ran f1/5 - 8
Rack1SW1(config-if-range)#switchport access vlan 10
3) Assign the IP address under the SVIs
Rack1SW1(config)#int vlan 10
Rack1SW1(config-if)#ip add 10.10.10.1 255.255.255.0
Rack1SW1(config-if)#int vlan 20
Rack1SW1(config-if)#ip add 10.20.20.1 255.255.255.0
4) Then configure NAT as you would on a regular router but place the ip nat inside under interface vlan 20 and ip nat outside under interface vlan 10
HTH,
__
Edison.
Please rate helpful posts
Overall Rating: 5 (1 ratings)
usmanjathol Fri, 09/12/2008 - 07:04
Thanks for your reply..
i could not find nat commands that works with built in switch ports. in 1811 / 1812
these are not routed ports.. right ?
usman
Edison Ortiz Fri, 09/12/2008 - 07:09
No, they aren't routed ports.
You need to place the NAT under the SVIs (Switch Virtual Interface).
HTH,
__
Edison.
usmanjathol Fri, 09/12/2008 - 07:31
thank you so much HTH,
can i get some specific example of that.. as i have to quote the same router some where .. and i have to prove that it will work that way..
thanks a lot
usman
ilkadmin-cco Fri, 09/12/2008 - 08:04
! 1. define vlan
vlan 10
name intern
! 2. put switchports into vlan
int fas 2
switchport mode access
no shutdown
! same for fas 3... fas 9
! fas 0 and fas 1 are real ethernet ports
! 3. configure ip
int vlan 10
ip address 10.1.1.1 255.255.255.0
no shutdown
ip nat inside
Yes, that also works with the default-vlan 1,
where initially all 8 switches ports
are members of.
Correct Answer
Edison Ortiz Fri, 09/12/2008 - 08:06
Usman,
VLAN 10 added:
VLAN 20 added:
HTH,
__
Edison.
