External antenna for WLAN Client Cardbus adapter
Sep 12th, 2008
hallo
is it possible to connect an external antenna to a wlan cardbus adapter like AIR-CB21AG-E-K9 ?
The data-sheet reports "Antenna: Integrated dual-band 2.4/5-GHz, 1-dBi, effective-gain antenna on a two-
meter cable"
I don't see an antenna connector on the adapter and I don't find any antenna cable adapter to connect an antenna !!
Can you help me ?
best regards
francesco
Overall Rating: 5 (2 ratings)
Scott Fella Fri, 09/12/2008 - 03:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What I have heard is that you would have to peel off the top "Sticker"..... you know the black thing that say's Cisco peel that off and it will expose the connector.
SJessulat_2 Fri, 09/12/2008 - 05:31
Wow, you're right.
I used this card for about 2 years and didn't know that, nice.
Scott Fella Fri, 09/12/2008 - 05:43
  • Hall of Fame,
    2017 Wireless
Yeah.... me too. They should of worked around that connector.
fsoffia Fri, 09/12/2008 - 07:13
hallo
are you sure that peeling off the black sticker we don't break the adapter ?
which kind of cable adapter we need to collegue an external antenna ?
is there a conversion kit from cisco ?
best regards
francesco
