GBIC or SFP Information
Sep 12th, 2008
Can anyone please let me know that how will I find the availability of GBIC or SFP card in its slot provided.
I am trying to find this for following device types
6509, 7200, 7500, 7600 & 29-00 devices.
I tried
"show diag" it gives information only up to port adapter level, no information is provided about the availability of the pluggable factors.
"show interface GigabitEthernet" I see some response even if the hardware is not plugged in.
Please help
MUHAMMAD SHAHEEN Fri, 09/12/2008 - 03:18
in CatOs, use > show port
and in IOS use # show int status
and look under the type column
Hope this Helps
Shaheen Fri, 09/12/2008 - 04:26
Thanks for the reply.
Since the "show int status" command is not supported across IOS version, I have concerns using this command for 12.0/12.1 versions.
Is there any other command that can help in this regard?
hamismai Mon, 09/15/2008 - 10:06
For the 6500 and 7600 one command might give you the information needed:
show idprom interface gigx/y
or for the entire module:
show idprom module x
For the 7200/7500 platform I am not aware of any command.
