CME 4.1 delete the "@IP-CME-PROXY" from called phone number
Answered Question
Sep 12th, 2008
hi,
ive a problem.
i have a working CME4.1 infrastructure with Nokia E65.
but if someone calls me on the Nokia, on the display there is the calling number with the @proxy-ip attached.
like: 5546554@10.10.10.15
but i like: 5546554
is that possible?
without translation rules?
thx
Correct Answer by pasimahone about 8 years 6 months ago
Did you install SIP voip settings tool?
It's an application to define advanced voip settings.
You have to define advanced settings via that application (installations->Sip voip settings).
Those settings are not visible in SIP settings.
-Pasi-
Overall Rating: 4 (2 ratings)
pasimahone Fri, 09/12/2008 - 05:55
  • Bronze, 100 points or more
elkono200 Fri, 09/12/2008 - 06:20
thx pasi,
but i haven't any "Ignoring domain part setting" in my SIP menu on my E65.
SCCP i have already installed also licensed. but i have some "private" Phones where i can't install my sccp licenses (only for company phones)
thx.
any other ideas.
Correct Answer
pasimahone Sun, 09/14/2008 - 22:26
-Pasi-
