NETWORK TRAFFIC/HOST MONITORING SOFTWARE
Sep 12th, 2008
please I am having serious challenge at work. Our branches are experience high latency and slow link. They is need for urgent BW upgrade,but of course first,the management needs a comprehensive network monitoring and analsysis. They want to know who(user) is doing what(protocol and application), and when(time). I notice cisco routers can really do this (please correct me). I need a good software to do this as my job is on the line.I am a CCNP and expectation is really high.
Overall Rating: 5 (1 ratings)
jjohnston1127 Fri, 09/12/2008 - 07:38
Enable NBAR protocol discovery and netflow in your routers.
If you want help with setting up flow exporting, let me know and I can provide you with the commands to do so.
Download the 30-day trial of NetFlow Analyzer and purchase an upgrade license if you are satisfied with the product.
It will break down traffic usage by time, protocol/port, IP address to/from, and much much more.
You can get it from here:
http://manageengine.adventnet.com/products/netflow/
Just Kennie Mon, 09/15/2008 - 00:36
After enabling nbar, will netflow be installed int the router or on a server. (2)is flow exporting need too.
Please i will appreciate a step by step analyis. Please i hope this work. have you used wireshark before?
cisco24x7 Wed, 09/17/2008 - 08:38
Having work with NetFlow Analyzer and NetQoS,
I can tell you that NetQoS is one of the best
products out there for analyzing NetFlow.
In my opinion, it is NetQoS is much better
than NetFlow Analyzer from Advent Engine.
NetQoS is not cheap either but comparing NetQoS
to NetFlow Analyzer is like comparing Porsche
to low-end American cars.
