How to set RRM parameters
jcosgrove
Is there any way to set the RRM parameters such as max power or channel selection for AP's. I would like to have the network set their own settings but would like to set a max power for the AP's
2 Accepted Solutions
bbxie
Level 3
Level 3
yes, you can set RRM parameters through GUI:Wireless > 802.11a/n or 802.11b/g/n > RRM
or by using CLI such as "config {802.11a | 802.11b}xxx" or "config advanced {802.11a | 802.11b} xxx", for example if you want to set a max 11a TX power for AP, you can use "config 802.11a txPower global 1". You can refer to following link for more detailed information:
http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51rrm.html
jaichauh
bbxie
Level 3
Level 3
