Problems probing for rogue access points
Sep 12th, 2008
I have a situation where I am trying to locate a rogue AP in one of my office buildings. When I bring a laptop over there with NetStumbler or Inssider, I get no response from any access points or clients. Its like that throughout the entire building. However when I leave the building, the AP start to come up but I cant get near them.
I have another build that we have as well and the probing works just fine. Would there be a controller template or access point template that would be causing this problem?
Here is what I am running:
Cisco 4400 controller with firmware 4.2.130.0
Cisco 4400 controller with firmware 5.0.148.0
Cisco WCS 5.1.64.0
The access points that are connected to the controller with a firmware of 4.2.130.0 is the one that seems to be stopping my attempts with probing. So far my searching for causes has not turned up anything=(
Any help would be greatly appreciative.
Scott Fella Fri, 09/12/2008 - 05:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What are you seeing in the logs? Are the two controllers being used as primary and secondary? You should keep the code the same, just in case ap's move to the other controller?
When you see a rouge ap, it will also state which ap's are hearing that rouge ap and the signal strength. If you see it -86db or worse, then it is outside of your building most likely.
ericn8484_2 Fri, 09/12/2008 - 06:42
Looks like its to late to see my logs from when I was last testing. I will try it again and see what the logs tell me.
The reason we are running two different firmwares is because we have recently added Cisco 7921 phones and the 5.0.148.0 firmware has a bug where it will lock up the 7921 phones. So we have one controller running older firmware for testing.
Scott Fella Fri, 09/12/2008 - 06:48
  • Hall of Fame,
    2017 Wireless
4.2.130 is a Cisco gold code along with 4.1.185. 5.0 is buggy and 5.1 is too new.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
