5.1.X CCM Route Pattern Question
Sep 12th, 2008
I am trying to get a 4 digit 6XXX and a 5 digit 6XXXX work without interdigit timeout.
I tried checking the urgent priority for 6XXX but still waits for the extra digit (likely due to the existing 6XXXX).
Customer needs both to work. I tried 6XXX# and still does not work.
There is a gatekeeper invoved in the architecture - hope that is not involved.
I tried 6! and still the 6XXX# does not work. Any suggestions? Thank you.
Chris Deren Fri, 09/12/2008 - 06:50
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You cannot make them work without interdigit timout on CM. You will need to have more specific non-overlapping pattern to elimiate the inter-digit timeout.
Sorry, HTH
Chris
whanson Fri, 09/12/2008 - 07:01
create a route pattern #6xxx then remove the # in the route pattern.
