Secure ACS - Remote Agent CLI
Sep 12th, 2008
Hello.
We have a Secure ACS 4.1 Solution Engine. I would like to use the Remote Agent CLI to export users but I don't understand how (or where) to launch the Remote Agent CLI. Does it run from one of our Remote Agent workstations?
Any help would be greatly appreciated.
Overall Rating: 4 (1 ratings)
Premdeep Banga Fri, 09/12/2008 - 05:55
You cannot do that using Remote Agent.
May I ask what do you ultimately want to achieve by exporting users from ACS 4.1, and what is your impression that what will you have in that exported user's ?
Prem
Please rate if it helps!
sometechguy Fri, 09/12/2008 - 06:09
The device is at a remote site. From the documentation, it appears that this can be done remotely. Is this not possible?
Premdeep Banga Fri, 09/12/2008 - 06:12
Which documentation are you referring to ?
AFAIK, we need serial console access for ACS SE to get this done.
Prem
