Warning message
T38 issue with MTP enabled on H323 Gw CUCM6.0.1
Sep 12th, 2008
On CUCM6.0.1 we use mobileconnect with access to midcall features like transfer.To do that we have to validate the "MTP Required" option on the gateway. This is our H323 PRI PSTN gateway (3825) through which outgoing calls to mobiles go and through which we access mobileconnect DID number. But this gateway support also incomming and ougoing fax calls to and from a H323 VG224. When MTP is not validate, all fax calls are T38 (14400) and work very well, when MTP is validate all fax calls fall back to Cisco Fax-relay mode and fail very often. Why is t38 imcompatible with MTP?
Michael Owuor Fri, 09/12/2008 - 07:19
  • Cisco Employee,
Hi Guy,
If the MTP being invoked here is a software MTP, that might explain why the T.38 calls are failing. Software MTP does not support T.38 fax. Try invoking a hardware based MTP resource such as the SVC-CMM-ACT module in Cat6K or the 6608.
Hope this helps.
Michael.
guy.richard Fri, 09/12/2008 - 09:04
Hi Michael
Thanks a lot for your answer. I thought about software MTP and T38 but could not find any reading on it. Do you think a Hardware MTP on my 3825 (PVDM2) will fix the issue ?
Guy
Michael Owuor Fri, 09/12/2008 - 09:55
  • Cisco Employee,
Hi Guy,
I believe it will. Here's the output of the capabilities on of the MTP/Transcoders on my 2821 using the PVDM2's. Notice it includes support for passthrough.
BR2(config)#dspfarm profile 800 mtp
BR2(config-dspfarm-profile)#codec ?
g711alaw G.711 A Law 64000 bps
g711ulaw G.711 u Law 64000 bps
g722-64 G722r64
g729abr8 G.729ab 8000 bps
g729ar8 G.729a 8000 bps
g729br8 G.729b 8000 bps
g729r8 G.729 8000 bps
ilbc ILBC codec
pass-through Stream Pass Through
BR2(config)#dspfarm profile 801 transc
g722-64 G722r64
g723r53 G.723.1 5300 bps
g723r63 G.723.1 6300 bps
gsmamr-nb GSMAMR codec
ilbc ILBC codec
Hope this helps.
Michael.
guy.richard Fri, 09/12/2008 - 22:53
Thanks a lot,
I'll try this next monday and write you back the result. Have a good week-end
Kind Regards
Guy
guy.richard Wed, 09/17/2008 - 05:19
Hi Michael
This night I've upgraded my 3825 to ipvoice 12.4-20T to have "sccp ccm 172.17.1.1 identifier 1 version 6.0+" availiable in the gateway config.
I tried software and hardware in the dspfarm profile. This the only one MTP the gateway can require through its MRGL / MRG.
As soon as I validate "MTP require" in the CUCM gateway config, I have no more fax.
Why can I put only one codec in the profile ? I tried G711Alaw and G711uLaw
Guy
sccp local BVI100
sccp ccm group 1
associate ccm 1 priority 1
associate profile 10 register XCOD_3825-1_NY
associate profile 20 register CFB_3825-1_NY
associate profile 30 register MTP_3825-1_NY
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions software 100
associate application SCCP
Michael Owuor Wed, 09/17/2008 - 06:45
  • Cisco Employee,
Hi Guy,
On the dspfarm profile, add codec passthrough, so that the configuration looks as follows:
codec g711ulaw
codec pass-through
Reset the MTP with 'no sccp' followed by 'sccp', then verify that it is registered with CallManager by looking at the output of 'show sccp' and the configuration page in CallManager.
In CallManager verify that the MRGL, and MRG configuration provides access to this MTP resource.
When testing, please gather the output of 'debug h225 asn1' and 'debug h245 asn1'.
Michael.
guy.richard Wed, 09/17/2008 - 09:44
Hi Michael,
I think you are right. I am not at my customer but I have tested it on my lab with an AudioCodes MP112 -> CUCM6 -> Gw2811 in H323
Without codec passthrought in MTP profile, fax goes on Cisco mode and then G711 because MP112 does not support Cisco mode.
With passthrought, fax goes on t38 14400bps.
In fact I am developping a small IVR in Tcl to accomodate with mobileConnect transfert.
When the call is on the mobile, the user dials *1 to put on hold then dials a shortcut to the FeatureAccess DID number the the script answers collect the digits the user dials, he can press bad digits, no matter, he just has to have the good 4 last then he press #
The script collects the last 4 digits, setup a leg to the CUCM then send 1234# (same PIN for every mobile users) then sends *2 (transfer) then sends the last 4 digits and # so the transfer can be achieved. The probleme was no error correction on digits and too many digits to dials.
I am looking for mobile able to send a few digits after connection (the user could configure his PIN after the DID)
Kind Regards and Thank you so much
Guy
