BPDU Guard
Answered Question
Sep 12th, 2008
  • Cisco Employee,
If BPDU guard is enabled globally, then BPDU guard is disabled on a specific port, does this cause BPDU guard to no longer be globally enabled for the rest of the ports? In CatOS, hybrid, or Native. Thanks
Overall Rating: 4 (1 ratings)
Edison Ortiz Fri, 09/12/2008 - 07:02
  • Hall of Fame,
    Founding Member
If you enable BPDUGuard globally, it will be enabled on switchports with portfast enabled.
You can disable BPDUGuard on a specific switchport but this won't affect the rest of the switchports that are configured for BPDUGuard.
HTH,
__
Edison.
satish_zanjurne Fri, 09/12/2008 - 07:06
  • Silver, 250 points or more
You can override the spanning-tree portfast bpduguard default global configuration command by
using the spanning-tree bdpuguard interface configuration command.
So if you disable for specific interface, it will not disable globally.
HTH..rate if helpful...
mknewnam Fri, 09/12/2008 - 08:36
  • Cisco Employee,
Thanks for the replies. So BPDU Guard enabled globally can be overridden by the port's config if it disables BPDU Guard, but that doesn't affect the other ports. That makes sense. And this should hold true regardless of CatOS, Native, or Hybrid, right?
Correct Answer
Edison Ortiz Fri, 09/12/2008 - 09:42
  • Hall of Fame,
    Founding Member
