Help please with Aironet 1200 (AP1220B)
Sep 12th, 2008
I need help with a 1200 series Aironet. When doing a SH IP INT BRIEF it is showing RESET on the Dot1Radio0 interface.
Dot11Radio0 Status reset
What does this mean? and how to I initiate this interface? is it because I do not have the extended radio antenna plugged in?
Thanks in advance.
BVI1 10.188.100.6 YES NVRAM down down
Dot11Radio0 unassigned YES NVRAM reset down
FastEthernet0 unassigned YES NVRAM up down
**EDIT**
I have consoled into the second WAP with IP 10.188.100.5 and it is not showing this problem.
Could it be that 10.188.100.6 has a damaged or malfunctioning radio antenna?
jaichauh Fri, 09/12/2008 - 07:58
Hi!
Please check the station role; it should be Root or Access point on the AP and SSID is enabled on the radio.
If SSID is configured and role is set as desired, do a hard reset on the AP and see if it helps.
Check the LED status as well. Review the link for LED indication:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1076792
-Jai
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
