ASA Between Two Buildings W/ Diff Subnets. How Do I extend the Network?
Answered Question
Sep 12th, 2008
I have two buildings with two different networks. Users at building one want to be on the network at building two. Standard routing obviously won't work so should I put two ASA at both buildings and [IPSEC] VPN between buildings extending the network? Will this work? If so, where are the commands in the ASA Config Guide?
Thanks...if you can get this to me very quick.
Matt
Correct Answer by JORGE RODRIGUEZ about 8 years 6 months ago
Matt, a litle more info would help, are each building totally separate in terms of physical connectivity any fiber in between them, are both buildings the same company? does each have its own Internet ISP?
If there is no connectivity between them other than the internet and if each building have its own ISP it is assume then that there is already a firewall , if this is the case you can implement L2L vpn and connect the two networks via Ipsec over internet.
Here is a typical scenario
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080950890.shtml
Rgds
Jorge
PLS rate any helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 09/12/2008 - 08:48
  • Green, 3000 points or more
Rgds
Jorge
