IP Communicator over wireless not registering
Sep 12th, 2008
Looking for others that may have run into this, IP Communicator will not register when using wireless network but does on same machine over wired network.
Thanks in advance for the help.
Overall Rating: 5 (2 ratings)
Jaime Valencia Fri, 09/12/2008 - 09:25
hardcode the device name under CIPC config and use that one to register it in CUCM
if this helps, please rate
terryabbott Fri, 09/12/2008 - 09:45
That is how we do our IP Communicators. We still have the problem not registering.
rtrees Fri, 09/12/2008 - 12:14
I have a similar problem where it tries to start and says that it "Could not find a network adapter needed for registration" but like you it only happens when I am on wireless and not when wired. It has done this for the last several versions. The only way to get it working that I have found is to uninstall, reboot, and reinstall. This will get it working for a time or two but then it does it again later.
terryabbott Fri, 09/19/2008 - 11:09
I found the solution to my problem. I had to disable the VLAN Priority Support value under the advanced tab of the wireless card. After that the IP Communicator (v2.1.2) registered fine.
