Troubleshooting VPN drops between 871 client and 2811
Sep 12th, 2008
My small company uses a 2811 ISR for VPN services (among other tasks such as internet access, p2p circuits to a second site, etc). I have a couple of remote users that have 871 routers that have occasional problems with their routers dropping their VPN tunnels to the 2811. I'm not really sure where to start with the troubleshooting. There are other clients (such as my own 871W) that seem to maintain a connection for weeks. These remote routers that do drop the connection usually reconnect at their next schedule attempt (180 seconds or so.)
Most of the previous questions I've seen similar to this involve software clients but these are hardware routers as the clients and as such I'm not sure how to enable or retrieve logs for the VPN sessions.
singhsaju Fri, 09/12/2008 - 11:53
  • Silver, 250 points or more
Hi Cameron,
Make sure the lifetime for phase1 > lifetime for phase2 for these tunnels. Because IPsec SAs are built inside Isakmp SA.
Usually the lifetime for phase 1 SA is 86400 seconds and phase 2 is 3600 seconds.
Can you verify this?
Saju
Pls rate helpful posts
cclarkacs Fri, 09/12/2008 - 12:23
Saju,
On the 2811 config there does not appear to be any ipsec or isakmp lifetime statements, so I think it would be using the default values for phases 1 and 2?
Is there a way to get the router to output the configured lifetimes?
singhsaju Fri, 09/12/2008 - 12:28
"show crypto isakmp policy" and "show crypto ipsec sa" can show you lifetime .
cclarkacs Fri, 09/12/2008 - 12:39
As expected, the isakmp lifetime is 86400, but for ipsec it merely reports how much time is left in the current sa.
For example:
router#show crypto isakmp policy
Global IKE policy
Protection suite of priority 3
encryption algorithm: Three key triple DES
hash algorithm: Secure Hash Standard
authentication method: Pre-Shared Key
Diffie-Hellman group: #2 (1024 bit)
lifetime: 86400 seconds, no volume limit
Default protection suite
encryption algorithm: DES - Data Encryption Standard (56 bit keys).
authentication method: Rivest-Shamir-Adleman Signature
Diffie-Hellman group: #1 (768 bit)
router#show crypto ipsec sa
interface: Virtual-Access4
Crypto map tag: Virtual-Access4-head-0, local addr 209.XXX.XXX.82
protected vrf: (none)
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer 75.XXX.XXX.179 port 4500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 681527, #pkts encrypt: 681527, #pkts digest: 681527
#pkts decaps: 670316, #pkts decrypt: 670316, #pkts verify: 670316
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 1, #recv errors 0
local crypto endpt.: 209.XXX.XXX.82, remote crypto endpt.: 75.XXX.XXX.179
path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1
current outbound spi: 0xF0C2D65C(4039300700)
inbound esp sas:
spi: 0x2A7171E4(712077796)
transform: esp-3des esp-sha-hmac ,
in use settings ={Tunnel UDP-Encaps, }
conn id: 4093, flow_id: NETGX:2093, crypto map: Virtual-Access4-head-0
sa timing: remaining key lifetime (k/sec): (4577435/1047)
IV size: 8 bytes
replay detection support: Y
Status: ACTIVE
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 4094, flow_id: NETGX:2094, crypto map: Virtual-Access4-head-0
sa timing: remaining key lifetime (k/sec): (4572865/1027)
IV size: 8 bytes
Status: ACTIVE
outbound ah sas:
outbound pcp sas:
singhsaju Fri, 09/12/2008 - 12:43
so phase1 is 86400 seconds and phase 2 is 3600 seconds.thats ok
you can also consider enabling isakmp keepalives between vpn nodes.
cclarkacs Fri, 09/12/2008 - 12:45
is that something that should be configured only on the server or also on the clients?
singhsaju Fri, 09/12/2008 - 12:51
Hi Cameron,
On both sides , server as well as clients.
crypto isakmp keepalive seconds [retries] [periodic | on-demand]
example: crypto isakmp keepalive 20
From the link below :
To allow the gateway to send dead peer detection (DPD) messages to the peer, use the crypto isakmp keepalive command in global configuration mode
http://www.cisco.com/en/US/docs/ios/12_3t/secur/command/reference/sec_c2gt.html#wp1199835
Saju
cclarkacs Fri, 09/12/2008 - 13:20
I had insert a similar statement yesterday on the server:
crypto isakmp keepalive 10 periodic
Should I set it to 20 sec instead of 10?
Anyway... where else can we look for the problem? The drops do not seem to occur at regular intervals, its somewhat random and for that reason I didn't suspect sa reconnection to be the culprit. And as I mentioned one of the clients (the router in my home office) doesn't seem to be dropped very often if at all.
However, I have now gone ahead and set the keepalive 20 on the remote routers.
So... what next?
