show adjacency int command in cef
Answered Question
Sep 12th, 2008
  • Bronze, 100 points or more
hi every body!
I need some help with the following:
switch# show adjacency fastethernet 6/1
protocol int address
ip f6/1 100.100.100.1(9)
What is"9" in the above line?
00d004823400800
epoch:0
what is epoch in the aboce line?
thanks a lot and have a nice day!
Correct Answer by Jon Marshall about 8 years 9 months ago
Sarah
Have a look at this link - scroll down to the table and all the output is explained. Please come back if you need further clarification.
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094303.shtml#topic1
Jon
Overall Rating: 5 (1 ratings)
sarahr202 Fri, 09/12/2008 - 12:18
Thanks a lot Jon.marshall!
Jon Marshall Fri, 09/12/2008 - 11:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ullas
I'm not sure it does. According to the doc i posted the number in brackets after the IP address is the number of times this adjacency is pointed to by FIB entries.
Jon
ullasupendran Fri, 09/12/2008 - 11:27
hi jon
You document looks correct.I mistook the protocol parameter of command ref in the link i send .
Ullas
