2801 - 1700 IPSEC VPN ISSUES
Answered Question
Sep 12th, 2008
Current set up is Static to Static,
due to ISP changes we are loosing the static on the 1700. If I setup dynamic DNS behind the 1700 could I use a FQDN in the crypo isakmp policy?
i.e.) crypto isakmp key <thekey> address <the FQDN>
and then in the map do
crypto map <name> <#> ipsec-isakmp
set peer <the FQDN>
set transform-set <transform>
the 1700 is an ISDN connection
alternative is going T1 at X2 the cost and buying a WIC, and a plane ticket....
Correct Answer by Farrukh Haroon about 8 years 4 months ago
Yes you can, you can use different sequence numbers for the two crypto maps. Place the static one first and then the dynamic one.
Farrukh
Overall Rating: 5 (1 ratings)
peterbertels Sun, 09/14/2008 - 19:38
ok but i have current static to static ipsec tunnels... and need to change just one tunnel to use dynamic...
the HQ router is a 2801
will it allow both static and one dynamic crypto maps ?? on the same router ?
pb
Correct Answer
Farrukh Haroon Sun, 09/14/2008 - 23:45
Farrukh
peterbertels Mon, 09/15/2008 - 08:11
Thankyou..
I have have GRE running inside IPSEC...
I added a dynamic-map and then added the crypto map dynamic
then removed the static for that link.. and reloaded the remote router... it still has its old IP address but it did connect... my only concern is that when the IP changes there will be routing issues.
Thank you for your help. It was very helpful to me with a very short time frame.
pb
Farrukh Haroon Mon, 09/15/2008 - 08:35
No if everything is setup correctly, there shall be no routing issues.
Farrukh
