09-12-2008 12:46 PM
Hi all,
Haven't found the info in the Knowledge base so here is my problem/question :)
next week I will change the IP addresses of my Ironport appliances. These 2 are in an Ironport Cluster.
What's the best way to do it ? Destroy the cluster and re-create it from scratch or is there another way ?
I thougt I would do it this way :
- Remove the 1st machine from the cluster
- Remove the 2nd machine from the cluster (then they would both work as stand-alone applicances, right ?)
- Change the IP of the first one
- Recreate a cluster on the first one (only with one node)
- Chnage the IP of the second one
- Add the second one to the cluster
Is that the correct way to do it ?
Do I face any risk of loosing the configuration ?
Thanks for your help !
Fred
09-12-2008 11:41 PM
I went over your steps and they look good. Somethings I would emphasize are:
1. Make sure you do a "removemachine" and not an "administrative disconnect". When you run the "removemachine" command on BOTH systems, it will completely take it out of the cluster. The "administrative disconnect" is like hitting the Pause button with respect to the synching up between the clustered appliances. Changes that you make are queued up and will be implemented once it's off of the admin disconnect.
2. As far as configuration backups, I would do this. Before removing the machines, do a configuration backup on one of the machines. Though you can't directly import this configuration into the appliance, if needed, Customer Support can sift through the clustered configuration backup file and re-assemble it to be useful.
Second, after you remove both machines, perform a configuration backup on both machines individually just to be safe.
3. There's no rush to create a new cluster after you've changed the IP of machine1. Just change the IP on machine1 and verify mail is flowing.
tail mail_logs
Once that checks out, upgrade the IP on machine2. Verify mail flow on machine2.
Then create the cluster and join the 2nd machine to the cluster.
By the way, as a good practice, perform a configuration backup prior to do an AsyncOS upgrade.
Other than that, all your points are fine.
Hi all,
Fred
09-13-2008 12:29 AM
Our cluster is configured to use host names rather than IP addresses to identify the cluster members. If we make sure we do the DNS properly (lower the TTLs beforehand, etc.), then is all this rigamarole necessary? Shouldn't we be able to disconnect, change the address, reboot the unit, and rejoin the cluster?
09-17-2008 11:35 PM
Networkh,
How did changing of the IP interfaces for your clustered machines go? Did everything go as plan? I'd be interested on how it went.
Kevin
09-18-2008 07:57 AM
Networkh,
Kevin
09-18-2008 01:02 PM
I'm actually going through a similar process at the moment, migrating 4 Ironports from using single IP addresses to 5 Virtual Gateway addresses. This is so we can segregate traffic into different streams. I'm using altsrchost to send mail off to different IPs.
So far the biggest problem is definitely the greylisting and throttling we are experiencing moving to IPs with no / neutral reputation scores (and not everyone uses SBRS as their database either!)
We are moving fairly slowly, monitoring the bounce logs and suspending outbound listeners if a particular host has a large build up of mail.
