Joe Clarke Fri, 09/12/2008 - 16:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Campus Manager only supports Cisco IP phones registered to a Cisco Call Manager. Campus does not currently support CCM version 5.x or 6.x software. Make sure your CCMs are showing up properly on the Topology Map with green application server icons. Make sure the phones first show up in User Tracking as regular end hosts. Only then will UT query the ccmPhoneTable on the CCMs to get the IP phone details.
robetrem Tue, 09/16/2008 - 05:44
any ideas when ccm 6.1 will be supported by campus ?
Joe Clarke Tue, 09/16/2008 - 05:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This October with the IDU 21.0 release.
robetrem Tue, 09/16/2008 - 06:01
Will be support in LMS 3.0 or need LMS 3.1 ?
Joe Clarke Tue, 09/16/2008 - 06:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There will be support for LMS 2.6, 3.0, and 3.1.
Joe Clarke Wed, 10/22/2008 - 19:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
In order for a phone to show up as an end host, it must be connected to a Cisco switch which has been properly Data Collected by Campus Manager, and shows up on the Topology Map with a green switch icon. Depending on the switch type, the port to which the phone connects must also be an access port and not a trunk port. However, this can be worked around in Campus 5.0 by enabling trunk port acquisition. Next, the phone must appear in that switch's CAM/MAC table. If SNMPv1 or v2c is being used on the switch, the switch's community string must not contain a '@'. If SNMPv3 is being used, then the switch must be configured for SNMPv3 contexts, and the VLAN which contains the phone must be an allowed context.
n-venkatapathy Thu, 11/13/2008 - 15:31
Has the patch been released for LMS2.6 for the support of IP Phones to be tracked in Campus Manager User Tracking Acquistion from CCMv5.0 and CCMv6.0?
Joe Clarke Thu, 11/13/2008 - 15:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, Campus 4.0.12 is now available.
n-venkatapathy Thu, 11/13/2008 - 15:56
Well, I have upgraded Campus Manager instances to 4.0.12, ran Data Collection and User Tracking Acquisition after the upgrade, but still IP Phones are not getting tracked.
Joe Clarke Thu, 11/13/2008 - 20:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should start a new thread on this.
george.goebel Thu, 10/23/2008 - 07:46
We have CCM version 6.X and LMS 3.0, we have approximately 1500 IP Phones. We have the known problem of incompatibility too. Is this IDU 21.0 the fix for the incompatibility. Is it available yet. Will it be included in LMS version 3.1 Thanks.
kenglim84 Thu, 10/30/2008 - 00:38
any ideas when ccm 7.0 will be supported by campus ?
I using LMS 3.1, Campus 5.1, CCM 7.0.
Problem: My IP Phones are discovered as end hosts. There isn't any discovery of IP Phone when I use quick report.
Joe Clarke Thu, 10/30/2008 - 06:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The CM 5.1.1 patch is planned for early November.
george.goebel Thu, 10/30/2008 - 07:01
Will this patch allow the Call Manager version 6.x work with LMS 3.1 for IP Phone discovery. Thanks.
Joe Clarke Thu, 10/30/2008 - 07:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
kenglim84 Thu, 10/30/2008 - 07:18
Will this patch allow the Call Manager version 7.x work with LMS 3.1 for IP Phone discovery. Thanks
Joe Clarke Thu, 10/30/2008 - 07:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
