09-12-2008 04:42 PM - edited 03-06-2019 01:21 AM
I currently have a 2960 witch with 2 VLANs on it (VLAN 99 and VLAN 102). The switches are connected to two 4507s via trunks.
I want the host in VLAN 99 to be able to communicate with only limited host in VLAN 102 on the 2 4507s.
I have included a drawing.
The only way I can figure to do that is by putting access-list on all the intefaces in the 4507, of course this makes no since.
Any ideas would be appreciated.
09-12-2008 05:06 PM
The only place you would need to put an ACL is on vlan interface of VLAN 90.
ip access-list ext hello
permit ip h.h.h.h n.n.n.n h.h.h.h n.n.n.n
Int vlan 90
ip access-group hello in
09-12-2008 05:56 PM
Are you talking about putting an ACL on the int VLAN 99 on each of the 4507s?
I thought of that but felt that would only control traffic going to that particular int on either of the 2 4507s. It would not control traffic on any other interface.
I dont think the 4507 supports VACLs and isn't that what you are speaking of?
09-12-2008 06:10 PM
first of all VACL filter trafic withing the same valn while ur case between two diffrent vlans
u can achived as mentioned by the prevouse post through ACL and apply it to vlan 99
for example lets say valn 99 is 10.99.1.0/24
and vlan 2 is 10.2.1.0/24
u want hosts in vlan 99 to communicate with only two hosts for eaxmple 10.2.1.1 and 10.2.1.2
access-list 100 permit ip 10.99.1.0 0.0.0.255 host 10.2.1.1
access-list 100 permit ip 10.99.1.0 0.0.0.255 host 10.2.1.2
interface vlan 99
ip access-group 100 in
by the way those permited hosts in vlan 2 will only be able to communicate with hosts in vlan 99 because this ACL will filter the returen path for communication from 2 to 99 as well
if helpful Rate
