tftp server problem
Sep 12th, 2008
i am trying to access my tftp server (a win xp pro machine), i have turned off windows firewall, enabled write access sharing for the home folder, but when i do copy flash tftp, i am getting tftp error code 2, write access denied, i can see that tftp server is getting the request for cisco router, but still something is blocking write access, also cant do copy tftp flash
any help will be appreciated. thanks
scottmac Sat, 09/13/2008 - 09:01
  • Green, 3000 points or more
Which TFTP server are you using on the XP machine?
How big is the file you are trying to upload?
I like the 3cDaemon (version 2.10), it's never failed me, and it doesn't have the 32 Meg limit that most of the other servers do (like SolarWind)
Chances are you have not given the server a/the proper directory. It's usually easier to assign a default directory in the server application, then that appears as root ("/") to the client.
Good Luck
Scott
tperrier Tue, 09/16/2008 - 01:41
  • Silver, 250 points or more
I use tftpd32, simple and efficient (works with files over 32 MB too). You don't even have to install it, so you can just have it on a USB key along with your favorite IOS files, and launch it from there on whatever computer you're using at the time.
http://tftpd32.jounin.net/
