wan link call control
Answered Question
Sep 12th, 2008
Can anyone tell me how I can control the number of calls going across a wan link. I am aware you can use locations in CCM. This scenario however is different. 1 site is ccm and the other is a PBX. They are connected via 2 routers using QSIG. I was hoping there was something you can do on the routers
Correct Answer by Marwan ALshawi about 8 years 9 months ago
simply on the outgoing dial peer add the foolowing cammnad
dial-peer voice 9 voip
max-conn [max number of calls]
for wxample if u want to limit the number of calls to 9
do the following on the outbound voip dialpeer going to the other one
dial-peer voice 1 voip
max-conn 9
! 9 calls allowed on VoIP Dial Peer to Remote Site
good luck
if helpful Rate
Overall Rating: 5 (1 ratings)
Correct Answer
Marwan ALshawi Sat, 09/13/2008 - 00:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
max-conn 9
good luck
if helpful Rate
