6704-10gb port crossconnect issue. very odd.
gskhanna
Installed 2 new 6704-10gb blades in 2x 6509 routers.
Routers are already configured with 1x 10gb-LR crossconnect between each router with a simple /30 between them. Working fine.
After the upgrade. Initially I want to setup a 30gb port channel between the router, but for some reason, i was unable to ping across the interface. I then removed the channel, and just setup a /30 on a new interface and tried to ping across and could not. I also added an ipv6 address to each side and THAT was pingable.
Here is my config:
R1
| Single Mode fiber Cable.
R2
interface TenGigabitEthernet4/1
description int 4/1 test
ip address 10.1.1.2 255.255.255.0
no ip unreachables
no cdp enable
end
R1
ip address 10.1.1.1 255.255.255.0
no ip unreachables
end
Link lights come up fine, and like I said, if I add an ipv6 address to both sides, I can ping across. But I cannot ping 10.1.1.1 nor 10.1.1.2 from the other side.
Now I have 2x more 10gb blades in slot #3. When connected to t3/4 on both sides using the SAME 10GB-LR and same cable, and even same above configuration, it works fine.
Mod Ports Card Type Model Serial No.
2 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL10019B20
3 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL10019N7G
4 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1011G15Z
6 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL09159B62
Mod MAC addresses Hw Fw Sw Status
2 0030.f272.f2b2 to 0030.f272.f2e1 1.1 12.2(14r)S5 12.2(18)SXF9 Ok
3 001c.588f.07f0 to 001c.588f.07f3 2.6 12.2(14r)S5 12.2(18)SXF9 Ok
4 0016.c76c.01d4 to 0016.c76c.01d7 2.3 12.2(14r)S5 12.2(18)SXF9 Ok
6 0011.21ba.b0ec to 0011.21ba.b0ef 4.1 8.1(3) 12.2(18)SXF9 Ok
Mod Sub-Module Model Serial Hw Status
2 Distributed Forwarding Card WS-F6700-DFC3BXL SAD091907RF 3.1 Ok
3 Distributed Forwarding Card WS-F6700-DFC3BXL SAD114604SC 5.3 Ok
4 Distributed Forwarding Card WS-F6700-DFC3BXL SAL09285CE1 5.2 Ok
6 Policy Feature Card 3 WS-F6K-PFC3BXL SAD081702AG 1.2 Ok
6 MSFC3 Daughterboard WS-SUP720 SAD082607P2 2.1 Ok
Both routers have identical parts. This is driving me crazy. am I supposed to activate something for this new blade?
Thanks.
-Gurpreet
Giuseppe Larosa
Hello Gurpreet,
for correctly supporting the 6708 linecards with 8 10GE ports we needed to move from 12.2(18)SXF to 12.2(33)SHa.
What IOS release are you using ?
minimum version is 12.2(17a)SX
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/release/notes/OL_4164.html#wp2561983
Hope to help
Giuseppe
We are using:
Version 12.2(18)SXF9
If it didn't support it, then the other blade wouldn't be working fine.
Nor would ipv6 work :/
really odd that ipv4 doesn't work.
I even swapped blades around, and just doesn't work in slot 4 for ipv4.
