Cisco Soho 97
Sep 13th, 2008
I have a problem with a Cisco Soho 97 which has been passed onto myself.
When I start the unit up I receive the Green OK led, and two flashing green RXD and TXD leds constantly.
I cannot connect to the web interface and I have tried to connect to the console which seems to work but stops on the last line and I cannot do anything.
I have posted an output of the console session.
I would be very appreciative if someone could give me some advise.
Kev
drolemc Thu, 09/18/2008 - 08:17
  • Silver, 250 points or more
Console problems occur when the router becomes unresponsive to input at the console port. If the console is not responsive, it means that a high priority process prevents the console driver from responding to input. The default configuration selects the route processor (RP) in the lowest numbered slot. For the Cisco CRS-1 Multishelf System, the RP in the lowest numbered slot in the LCC configured as Rack 0 is selected as the primary RP and the designated shelf controller (DSC).
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080106fd7.shtml
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.5/troubleshooting/guide/tr35boo.html#wp1044047
