Router 2811 / when restart lose the configuration
Answered Question
Sep 13th, 2008
I apply the configuration in the router, save, copy run to star, review the config and all work ok, but when restart the router lose the configuration and ask if I want enter the initial configuration.
Correct Answer by Mark Yeates about 8 years 8 months ago
Walter,
This is more than likely from a previous password recovery. Your configuration register was probably not set back to the correct setting afterwords. Check out the link below to fix the configuration register.
0x2102 is the setting that you want.
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a65a5.shtml
HTH,
Mark
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Yeates Sat, 09/13/2008 - 16:11
  • Gold, 750 points or more
Walter,
HTH,
Mark
