Sep 13th, 2008
HI, i have already installed an ASA 5505. My service provider only led me one ip address public. Can i do create Static NAT to my services (web, ftp) with ip address of ASA.
JORGE RODRIGUEZ Sat, 09/13/2008 - 17:05
Yes you can, use the outside interface for static inbound connections, if your ISP is only giving you one public IP for your ASA outside interface addressing.
say your inside network is network and have webserver at, ftp server at, and telnet server at
the static commands and acl would be similar to :
Static entries
static (inside,outside) tcp interface 80 80 netmask
static (inside,outside) tcp interface 21 21 netmask
static (inside,outside) tcp interface 23 23 netmask
and so on
maybe create a tcp object group for these services to apply to an acl
object-group service TEST tcp
port-object eq 80
port-object eq 21
port-object eq 23
create the acl and apply it to outside interface
access-list outside_access_in extended permit tcp any interface outside object-group TEST log
access-group outside_access_in in interface outside
PLS rate any helpful post
