what is MSTP, PVST??
Sep 13th, 2008
what is MSTP, PVST?? How to configure MSTP and PVSt
Overall Rating: 4.5 (2 ratings)
bbxie Sat, 09/13/2008 - 19:39
MSTP is Multiple Spanning Tree Protocol. MST maps multiple VLANs into a spanning tree instance, with each instance having a spanning tree topology independent of other spanning tree instances.
PVST is Per Vlan Spanning Tree, that means it maps single VLAN into a spanning tree instance.
For configuration of MSTP and PVST, you can refer to following link:
or 6500's configuration guide:
Marwan ALshawi Sat, 09/13/2008 - 20:28
PVST is per vlan spanning-tree
with pvst each vlan will has its own spaning tree instances like the rooot bridge, secondary root and so on
for eaxmple one switch can be a root for vlan 10 for example and secondary or non-root for vlan 20 and so on
but when u have al of vlans for example u have 100 vlan in this case each vlan will has its own STP instances then will be very high CPU intensive work on the switch.. not scaleable
on the other hand MSTP multiple spaning tree
this way u gonna make for example on each switch two instances and then u can assign each vlan to one of the instances lets say u have 100 vlan 50 of then in one instance and other 50 will be on the other in stances
and instance one use switch1 as root and instnce two use switch2 as a root so that u can divid the vlans and at the same time u have only two in stances which is much better than with PVST when u had 100 instances
good luck
if helpful Rate
