Sub-interface routing
Sep 14th, 2008
Will a 2811 running 12.4(11)X/Advanced-Enterprise-Services route between sub interfaces?
I can't get traffic from f0/0.50 to route to f0/0.100. Both interfaces have IPs and are doing dot1q trunking.
Traffic from both these interface can route to f0/1.
glen.grant Sun, 09/14/2008 - 02:08
Can you post the interface config , probably something with that . It should route fine between subinterfaces , probably the trunk isn't setup correctly between the router and switch. If possible post the switch config also.
