bwilmoth Fri, 09/19/2008 - 06:12
  • Silver, 250 points or more
This example shows how to set the port speed to 100 Mbps on port 2/2:
Console> (enable) set port speed 2/2 100
Port 2/2 speed set to 100 Mbps.
Console> (enable)
Giuseppe Larosa Sat, 09/20/2008 - 01:47
  • Hall of Fame,
    Founding Member
Hello Alan,
console speed can be changed by modifying the config-register (this is true on routers)
to see current config-register value use sh ver in a telnet session if the value is different then 0x2102, or 0x102 change it with
conf t
config-register 0x2102
end
copy running-config startup-config
reload
I've found a reference to this other way:
line con 0
speed
However, I would do it on a telnet session not while using the console port.
Hope to help
Giuseppe
