CCM5 and transcoding
Sep 14th, 2008
Hello
I have ccm 5 and outside branch works in the g729 codec i need configure transcoding but then i try configure transcoding like in the documnetation
i see only ccm 4.1
scc ccm 192.168.22.20 identifier 1 version but my ver sion is 5.1
so how configure transcoding for ccm 5
m.govorov Mon, 09/15/2008 - 05:51
hello thank you for your response but in the voice gateway haven't ccm5 version
only 4.1
Jaime Valencia Mon, 09/15/2008 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    2011
if you don't have it simply try dropping the version command, many times that does the trick without doing an IOS upgrade
java
if this helps, please rate
kinwai Wed, 10/08/2008 - 05:06
i manage to use "version 4.1" with cucm 6.1
