Attendant Console Alert Configuration?
Sep 14th, 2008
Is there way to configure the Attendant Console Audible Alerts to play longer than half a second? The default file is 2 seconds, but only half a second plays. Ummm, not long enough to be alerted.
It's something within the files to change this. Has anything figured out how to change this behavior?
tim.giles Mon, 09/15/2008 - 00:52
  • Silver, 250 points or more
Once the "Enable Audible Alerts" checkbox has been seleted, AC will trigger a file from here when a new call comes in:
c:\Program Files\Cisco\Call Manager Attendant Console\audio
..and it will play its duration. I'm not sure why it's only playing half a second but you could try dropping a new file from another install into this directory to see if it improves anything.
Please rate useful posts..
epekou Sat, 10/04/2008 - 09:46
Did you find a solution to this issue? I am facing the same problem. Any help would be appreciated.
TIA,
Evi
