reg:suuggssion on router
Sep 15th, 2008
Dear sir,
The fallowing is possible on router
1. Every router is configured to be a part of any network, that is, a group of profiles are created in the router and router assumes the configuration depending on the network properties.
2. Every group/ profile shall contain a set of DHCP profiles, using which the router configures the end hosts.
3. A set of criteria, such as hostname, port addresses, or interesting traffic, can be used to select the group/ profile configuration
srini
satish_zanjurne Mon, 09/15/2008 - 01:52
Hi Srini,
Not sure whether it is possible with CiscoWorks !!!! or whether it is possible at all..
