bbxie Mon, 09/15/2008 - 02:57
  • Silver, 250 points or more
It depends on WCS's version. in 5.1,you can use following steps to recover password if you can remember your root username:
1. Change to the WCS bin folder.
2. Enter "passwd root-user " to change the WCS root password. The newpassword is the
root login password you choose.
pls. refer to following link for detail:
http://www.cisco.com/en/US/docs/wireless/wcs/5.1/configuration/guide/wcsmain.html#wp1086989
Scott Fella Mon, 09/15/2008 - 03:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Previous versions are the same:
Step 1 Change to the WCS bin folder.
Step 2 Perform one of the following:
Enter passwd root-user to change the WCS root password. The newpassword is the root login password you choose.
or
Enter passwd location-ftp-user to change the FTP user and password. The newuser and newpassword are the FTP user and password you choose.
Step 3 The following options are available with these commands:
•-q - to quiet the output
•-pause - to pause before exiting
•-gui - to switch to the graphical user interface
•-force - to skip prompting for configuration
Step 4 Start WCS.
Trending Topics - Security & Network
