GRE tunnel problem
Sep 15th, 2008
I have applied the below confgs on two remote cisco routers connected to internet,the tunnel status is up up but I cant ping the tunnel ip address,what might be the problem??
Router1:
int tunnel 1
tunnel source s0/0
tunnel destination x.x.x.x (f0/0 of R2)
Router2:
int tunnel 1
tunnel source f0/0 (real ip)
tunnel dest x.x.x.x (s0/0 of R1)
Marwan ALshawi Mon, 09/15/2008 - 05:20
do u have routing protocol configured?
have u included the tunel interfaces in ur routing
also put the tunnel mode
god luck
mohammady Mon, 09/15/2008 - 19:05
I dont have routing protocol also I use the default tunnel mode
mohammady Tue, 09/16/2008 - 04:13
the tunnel stat is up up but I cant ping the other end??for the route I have a default route on both routers.....
mohammady Tue, 09/16/2008 - 04:20
the two routers connected to service provider routers (internet connection)
mohammady Tue, 09/16/2008 - 04:24
really I dont know ,it is the service provider network>>>how can I make sure that the tunnel is working properly....???
To be honest - you need to know this.
As you will be using RFC1918 internal IP addresses. So you will NAT or your provider might NAT for you - you need a routable source and destination for the tunnel to work. You also need to know if there any devices in between the connection between the 2 sites that could be blocking the runnel. What is the connection to the internet?? MPLS? Frame-Relay? ADSL ??
Right now you don't have enought information - you need to do some digging.
HTH>
mohammady Wed, 09/17/2008 - 06:52
one of them has dedicated E1 connection and the other one connected to a second router in possession of our service provider and then to internet...
R1--->E1
R2--->service provider Router --->internet
it implies nothing really, only the interface that is the source is know and up/up and that the router has a valid "live" route in it's routing table for the destination.
Just for you - configure your end with the following:-
int tun1
keepalive 1 3
Then close the tunnel and re-open it....does it come back up/up ????
At the end of the day you can trick a tunnel into being up/up if you have the time and a spare router with 1 ethernet interface do this:-
do not connect any cables to the ethernet interface.
Give the interface an ip address of 192.168.1.1/24
create a tunnel 1
tunnel source <>
tunnel destination 192.168.2.1
ip route 192.168.2.1 255.255.255.255 <>
and here is the magic - in the ethernet interface configure "no keepalive" this tricks the interface to come up/up - the there wiull be a connected interface in the routing table of 192.168.1.0/24
As you have a configured static route 192.168.2.1 out of the ethernet interface - there will be a static route in the routing table. As the tunnel can see a valid route - without keepalives, it will bring the tunnel up!
Try it out - great fun.
Your issue is still the path from 1 site to the other site and going over the internet I presume, you have nat issues, blocking issues or just plain connectivity/routing issues.
HTH>
