discovery settings are deleted
Sep 15th, 2008
lms 3.0.1 on solaris 10
today I want to change the discovery settings but there are no definitions!
the last time (friday) there were all definitions ok (seed device, snmp, filter and so on) - now there are no settings!
where are the settings - can I recover the settings?
Joe Clarke Sun, 09/21/2008 - 08:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The settings are stored in XML format in NMSROOT/conf/csdiscovery/CSDiscovery-config.xml. This file is backed up with the regular LMS backup. Therefore, if you restore a known good backup, you will have your settings back. Without a backup, you will need to manually re-enter your settings.
