09-15-2008 04:06 AM
Hello!
I want to use "SSL Session-ID" sticky method in load-balancing, but can't find any info about it in 3.0(0)A1(2) sw configuration guides. Where i can find info about it? Or this method is supported only in old A2(1.0) release?
Thanks.
Solved! Go to Solution.
09-15-2008 05:22 AM
SSL Session ID Sticky to ensure Client Persistence
1. Demonstrate the ability to provide stickiness using SSL
Session ID. To do this you will need to the Generic Protocol Parsing
framework on ACE. With the right regular expression you will be successful!!
2. Before you begin to configure the SSL Sticky group, be sure that
you have allocated resources to the sticky group. Note this done in the
Admin context.
resource-class cart
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 1.00 maximum equal-to-min
context Lab-Cart-11
allocate-interface vlan 211
allocate-interface vlan 411
member cart
3. Create an SSL-v3 sticky group and associate the serverfarm. Good
idea to configure a sticky timeout value. This specifies the period of time
that the ACE keeps the sticky information in the sticky table. Note the ACE
resets the timer each time ACE opens connections matching that entry. Also
configure the Layer 4 sticky parameters for 32 bytes session ID.
sticky layer4-payload ssl-v3
timeout 600
serverfarm HTTPS-FARM
response sticky
layer4-payload offset 43 length 32 begin-pattern "\x20"
When a new session is established between client and server, the server
generates a session id. The session id is an arbitrary sequence of bytes.
The length of the session id is 16 bytes for SSLv2 sessions and between 1
and 32 bytes for SSLv3/TLSv1. The session id is not security critical but
must be unique for the server. Additionally, the session id is transmitted
in the clear when reusing the session so it must not contain sensitive
information.
4. Create a class-map to match the layer 4 payload.
class-map type generic match-any SSL-v3-32
2 match layer4-payload regex "\x16\x03\x00..\x01.*"
3 match layer4-payload regex "\x16\x03\x01..\x01.*"
5. Create a new generic load balance policy map and assoiciate the
sticky-serverfarm understand the class.
policy-map type loadbalance generic first-match SSL-v3-Sticky
class SSL-v3-32
sticky-serverfarm ssl-v3
6. Change to the client-vips policy map to represent the new
SSL-v3-Sticky policy you just created
policy-map multi-match client-vips
class VIP-HTTPS
loadbalance vip inservice
loadbalance policy SSL-v3-Sticky
loadbalance vip icmp-reply active
7. Verify the VIP is accessible by trying to hit the VIP.
8. View the connection using the show cons command.
Pod1-ACE/Lab-Cart-11# show conn
total current connections : 1
conn-id np dir proto vlan source destination
state
10 1 in TCP 211 209.165.201.11:1115 172.16.11.190:443
ESTAB
9. Interesting I can see that the first connection has been setup. Why
is ACE not load balancing the connection to the server?
10. Great I need to configure a L7 parameter map with a max parse-length
parameter-map type generic SSL-v3
set max-parse-length 70
11. Associate the parameter map to the client-vips policy map
class VIP-HTTPS
appl-parameter generic advanced-options SSL-v3
12. Verify the VIP is now accessible by trying to hit the VIP.
09-15-2008 05:22 AM
Admin context.
resource-class cart
context Lab-Cart-11
member cart
timeout 600
response sticky
information.
class SSL-v3-32
class VIP-HTTPS
state
ESTAB
class VIP-HTTPS
03-15-2010 10:30 AM
Could you kindly breakdown the below command(s) and what is it looking for?Is that a pattern within the SSL session ID for V3 and TLSV1?
raman
07-25-2010 06:37 AM
Did you ever get the answer to the breakdown of the string in the generic class map? I'm having issues understand those.
07-29-2010 11:55 AM
Anyone?
Thanks in advance!
07-30-2010 12:41 AM
This means match the following bytes 0x16 0x03 0x00 ANY ANY 0x01
This means match the following bytes 0x16 0x03 0x01 ANY ANY 0x01
The 0x16 indicates this is a handshake packet. 0x0301 indicates this TLSv1.0 and 0x0300 indicates SSL v3
Hope this helps.
Gilles.
09-29-2010 09:05 AM
Hi Gilles,
I come back on this thread as I have a fundamental question/comment in regard to stickyness using the SSL Session-ID. I don't understand how it can work actually...
Background :
As far as I understand, when a client wants to establish an SSL session with a server, it sends a first Client Hello, in which the session-ID length is set to zero. Then, the server sends a Server Hello with the session-ID set to a 32 byte value for SSLv3. Then, after the handshake is completed, the client and the server communicate via the established TCP session on port 443. As far as I also known it can be that the SSL handshake is renegotiated every two minutes, hence creating another Session-ID as well.
My concern is to be analyzed in 3 scenarios :
Case 1 : The ACE does not terminate the SSL session and the SSL session is permanent between the client and the server
In this case, the ACE has to select a real server at TCP session establishment time. Then, as long as the TCP session is established, all packets are directed to the selected server. So, if the SSL session is permanent, there is no stickyness requirement I think ?
Case 2 : The ACE does not terminate the SSL session and the SSL session is NOT permanent between the client and the server
In this situation, the ACE cannot stick the client to a real server because he has to select a server at TCP session establishment time. So, where is stickiness with session-ID useful here ?
Case 3 : The ACE terminates the SSL session
In this case, the session-ID is only valid between the client and the ACE itself. Then, it cannot be used for stickiness with the real servers.
I am maybe wrong, could you give me your comments ont that question ?
Thank you in advance,
Yves
