Performance Monitor 3.2.1
Sep 15th, 2008
I have installed Cisco Security Manager 3.2.1 with RME 4.1.1, AUS 3.2.1 along with Performance Monitor 3.2.1 version on the same server.
Iam able to add devices in RME, AUS and working fine with adding devices in CSM and able to discover the existing VPN's.
I properly configured SNMP RO community string, enabled HTTPS but unable to add devices in performance monitor.
I get the error " either the HTTPS was not enabled or the credentials are not correct."
HTTPS is enabled and proper credentials are entered and same is working fine when devices are added in CSM.
Can anyone help me on this.
Chandru
ckuriyar74 Mon, 09/15/2008 - 22:22
Hi Farrukh,
Its a good link.
I have created a username with same user password and enable password for PIX/ASA firewalls
If I create a new username with less priv level still I get the same error message.
Any other solution to resolve this issue?
Chandru
Farrukh Haroon Mon, 09/15/2008 - 23:32
Why don't you give this username privilege 15 only? Can you post outputs of
show run aaa
show run username (remove the passwords)
Farrukh
ckuriyar74 Mon, 09/15/2008 - 23:36
ASA5510# sh run aaa
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
ASA5510# sh run username
username admin password xxxxx encrypted privilege 15
username readonly password xxxxx encrypted privilege 5
Chandru
ckuriyar74 Tue, 09/16/2008 - 00:00
ASA5510# sh run http
http server enable
http 193.169.1.0 255.255.255.0 management
http 147.183.0.0 255.255.0.0 inside
http 10.1.0.0 255.255.0.0 inside
ASA5510#
I have 147.183.0.0 and 10.1.0.0 inside networks configured for HTTP access and CSM server is in 147.183.0.0 network
Chandru
Farrukh Haroon Tue, 09/16/2008 - 00:09
So in CPM when importing the device are you using username/passwd or also the enable password?
Farrukh
ckuriyar74 Tue, 09/16/2008 - 00:17
When I try to import I use the username admin and user password.
User password and enable password are the same.
If I change the user password I get the same error message.
Farrukh Haroon Tue, 09/16/2008 - 00:40
Can you post the screenshot of the page on which you are entering the username/password AFTER entering the values?
Also are you able to add other devices properly?
Did you also try to import using DCR file (exported from CiscoWorks)?
Farrukh
ckuriyar74 Tue, 09/16/2008 - 01:12
Iam not able to add any devices and unable to import using DCR file as well. I get the same error when import using DCR.
Devices-->Importing Devices-->Import-->Manually Add new devices-->
I have attached the screenshot.
Farrukh Haroon Tue, 09/16/2008 - 02:39
So you are putting username admin and the password in BOTh the fields below? Have you double checked this password by logging into the device itself? Is the SNMP community string correct? can you post 'show run snmp-server' output.
Is this PIX or ASA and which version?
Farrukh
ckuriyar74 Tue, 09/16/2008 - 02:50
yes, Iam using the correct password. We have standard passwords set. All the devices set user password & enable password same.
I can login to ASA using same password and it works fine. SNMP community is correct.
The ASA version is 8.0(3)
ASA5510# sh run snmp-server
snmp-server host inside 10.1.1.7 community public version 2c
snmp-server host inside 147.183.140.176 community public version 2c
snmp-server host inside 147.183.141.15 community public version 2c
snmp-server location India
snmp-server contact IT Operations
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
ASA5510#
Chandru
Farrukh Haroon Thu, 09/18/2008 - 01:45
Your ASA is running a 3des license right?
Also is 147.183.140.176 or 147.183.141.15 the CSM server?
Farrukh
ckuriyar74 Fri, 09/19/2008 - 01:49
Yes, ASA is running 3des license.
CSM server is 147.183.141.15
Chandru
ckuriyar74 Thu, 09/25/2008 - 05:24
I could able to import PIX/ASA when installed CSM 3.1.1 (Cisco Works 3.0.5 & Performance Monitor 3.0) successfully.
Is there any bugs OR issues with CSM 3.2.1 (with performance monitor 3.2.1) ?
Chandru
Farrukh Haroon Thu, 09/25/2008 - 08:22
I would suggest opening a TAC case, and let them troubleshoot it.
Farrukh
jagbir_singh Wed, 10/08/2008 - 20:34
Hi Chandru,
Have you got any support from TAC or any other sources as suggested by Farukh on this problem as i m facing the same problem.
Jagbir
ckuriyar74 Thu, 10/09/2008 - 23:50
Hi Jagbir,
I had opened a TAC case and the cisco engineer had reset the mcp database. After this iam able to import devices into performance monitor.
Chandru
ckuriyar74 Fri, 10/10/2008 - 04:14
Here is the procedure used to reinitialize the Performance Monitor database (MCP). Please keep in mind that this wipes out any data that is stored in the performance monitor application.
net stop crmdmgtd
c:\progra~1\CSCOpx\bin\perl dbRestoreOrig.pl dsn=mcp dmprefix=mcp
net start crmdmgtd
As a reference, here is the link to the defect webpage:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu99210
Please rate if this helps.
Chandru
