CCM installation issue
Sep 15th, 2008
We are trying to install CCM 3.3 ( lab purpose) on the following server :
CPU-HP Proliant DL 380G3 X 3.06 GHz
RAM- 1 G.B
HDD- SCSI HDD 146.8 *2
When the Hardware Detection CD is inserted, it gets stuck after sometime. We have tried 2 different CD packs, same result each time. These CD's work fine on other hardware.
Someone changed the RAID settings / removed a hard drive some time back. Can that be a cause?
Overall Rating: 4 (1 ratings)
Chris Deren Mon, 09/15/2008 - 05:58
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
This server is too new to work with CM 3.3 and any of the OS supported on that version i.e. 2000.2.7, you will either have to get a supported server for that version of CM, or install newer software.
Chris
singh-ashok Mon, 09/15/2008 - 23:31
Thanks Chris for your valuable input. Have a nice day.
Abhijit.
