flow-control mismatch on the CE and CAT???
Sep 15th, 2008
Hi.
We're having an intermitten connection.
I don't if this is related but the
sh ip bgp neigh output shows that the number routes advertized decrease and increase intermittently.
I noticed that the sh int output on the
CE shows that the output and input flow-control is XON, but at the catalyst switch, it says unsupported...
Is it normal?
If not, ow should I change it???
Thanks a lot
Giuseppe Larosa Tue, 09/16/2008 - 05:57
  • Hall of Fame,
    Founding Member
Hello Jayson,
post the output of the sh int gix/y on the router.
Is this a Cisco 7206VXR with NPE G2 or NPE-G1 ?
I've noticed this Xon settings on NPE-G2.
look if present to pause frames sent and pause frames received and if there are input errors like ignored.
Hope to help
Giuseppe
