WLC 4404 and LAG
Sep 15th, 2008
We are trying to setup the four ports on our 4404 wireless lan controller to use LAG connected to a 3560G switch. If we connect distribution port 1 to a switch trunked port the unit works as expected. However, if we create an etherchannel containing four gigabit ports we cannot connect to the unit and all the port status LED's remain orange on the switch. They pickup the physical connection but are unable to communicate with the 4404.
We have enabled LAG on the 4404 and have rebooted several times but to no avail. We are using copper SFP's, not fibre to connect to the switch. The 4404 is on software release 5.1.151. Can anyone suggest where we are going wrong?
Scott Fella Mon, 09/15/2008 - 07:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
How do you have the trunk ports and port channel setup?
On the switch run:
show etherchannel load-balance
Make sure it is set to src-dst-ip, if not then.
port-channel load-balance src-dst-ip
You Port Channel should look like this:
interface Port-channel2
description WLC
switchport
switchport access vlan 10
switchport trunk native vlan 10
switchport trunk allowed vlan 12,10,25
switchport mode trunk
Your trunk should look like this
interface GigabitEthernet1/45
description WLC
switchport
no cdp enable
channel-group 3 mode on
spanning-tree portfast
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
