2 Buildings, 2 controllers-How to keep seperate??
Sep 15th, 2008
I have 2 buildings with a different subnet each. I have to 4400's each with a different name but one keeps taking the other's AP's. I suspect it is because when the AP fires up it looks for that address in dns and because I have 2 buildings it has the same name but 2 different addresses.
Any way to force each one to be correct?
thanks
Gary
bbxie Mon, 09/15/2008 - 15:37
You can manually set each AP's primary controller and secondary controller, for example, you can configure building A's AP to use WLC1 as primary controller, use WLC2 as secondary controller; configure building B's AP to use WLC2 as primary controller, use WLC1 as secondary controller, go to Wireless-->Access Points-->ALL APs-->click the AP-->detail-->High Availability to configure, refer following link for detaile:
http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51lwap.html#wp1249029
