2 Performance Monitor link on CSM 3.2.1 Suite
Sep 15th, 2008
Hi, I just upgrdaded CSM from 3.1.1 sp3 to 3.2.1 sp1 with Performance Monitor 3.2.1.
Now I have 2 Performance Monitor icons on the CSM Suite, with only the new running.
How to remove the oldest ?
sadbulali Fri, 09/19/2008 - 13:34
Performance Monitor, which is an external status provider, must be registered with Security Manager and needs to be authenticated by Security Manager to send status on events it is monitoring.CSM 3.2.1 upgrade will not support pending data. You will have to approve or discard pending activities before upgrading.After you upgrade Security Manager, overwrite the existing version of the Security Manager client on your client system by running the 3.2.1 version of the client installation software. This will remove the older version from the sys
For more information about steps to be followed for proper ugrade of CSM:
