Cisco ACE: http-header based Stickiness
Sep 15th, 2008
Hi All,
I'm trying to configure a sticky policy to make HTTP sessions from Mobile Users to stick to the WAP Server they were served before. The IP-addressing based sticky policy is not ideal as the Mobile Users can roam around and use a different IP-Address.
So I configured the following http-header based sticky policy:
sticky http-header x-up-subno TD_Testing
timeout 2
replicate sticky
serverfarm TD_WWW
where x-up-subno is an HTTP header field containing Users' MSISDN, for example:
x-up-subno: MN002138210335\r\n
My question is if I apply the above stikcy policy to a policy-map would ACE loadbalance based on the header value? that is MSISDN, and NOT based on the header name itself.
My fear is that all the HTTP traffic will get diverted to a single WAP server as all of it will have that HTTP header.
Thanks!
- Kashif
Syed Iftekhar Ahmed Mon, 09/15/2008 - 10:40
  • Blue, 1500 points or more
Stickiness will be based on Header-value.
Header based functionality is similar to cookie based persistence.
Header-Name/Cookie-name tells ACE to look for that particular Header-field/Cookie-Name and then Stickiness is based on the Header/cookie value.
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
kasiddiq Mon, 09/15/2008 - 11:09
Thanks Iftekhar. I will test this in the lab and find out if it works.
- Kashif
