unity license
Sep 15th, 2008
After i physically installed the unity express module in the router i typed service-engine 1/0 session command.From there i need to install the cue-vm-license_12mbx_ccm_2.3.4.pkg package.
What command is required ?
hadbou Fri, 09/19/2008 - 13:30
  • Bronze, 100 points or more
What version of Unity are you using?
Jaime Valencia Fri, 09/19/2008 - 16:43
  • Cisco Employee,
  • Hall of Fame,
    2011
all the information is already on CCO, please try searching within cisco.com for the information you need or within netpro, be proactive
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/installation/guide/upg_3lic.html
Link to get the license. You can download either 25 or 50 license but make sure you get the cme file not ccm. Example:
cue-vm-25-license.1.1.2.cme.pkg
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-netmodule
java
if this helps, please rate
