unity license
Answered Question
Sep 15th, 2008
After i physically installed the unity express module in the router i typed service-engine 1/0 session command.From there i need to install the cue-vm-license_12mbx_ccm_2.3.4.pkg package.
What command is required ?
Correct Answer by Jaime Valencia about 8 years 1 month ago
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
if this helps, please rate
Overall Rating: 5 (1 ratings)
kolawole1 Mon, 09/15/2008 - 10:08
In the unity express integration to call manager i have the command:int loopback 0
It has been said that this is the ip address of the local router.
But in the actual architecture my router is already having an interface serving as default gateway for the call manager.Should I create another loopback interface for unity or should i use the existing router interface and modify his ip address ?
